Get all files inside the folder and select the excel file like cc.xlsx inside the folder
- Need to check whether folder is present or not - MJS isFolder(InputFolder)
- Get all file names inside the folder. - which option need to use
- Search and select the file like “Axis CC*.xlsx”. normally avilable “Axis CC 29June2019.xlsx”. next time “Axis CC 30July2019.xlsx” - which option need to use
How to use regex.
Dear Team,
Can you suggest the plugins.
Waiting for your reply…
Hi Manikandan,
Please see below reply to your questions:
Answer- You can use “Get File Names” plugins to get file names inside the folder.
Search and select the file like “Axis CC*.xlsx”. normally available “Axis CC 29June2019.xlsx”. next time “Axis CC 30July2019.xlsx” - which option need to use
Answer- You can try with a wildcard to select the specific file name from the folder.
