2021/02/09 10:57:24 - Start Browser.0 - ERROR (version 6.0.0 from 2020-12-29) : timeout: Timed out receiving message from renderer: -0.015 (Session info: chrome=88.0.4324.146) (Driver info: chromedriver=88.0.4324.96 (68dba2d8a0b149a1d3afac56fa74648032bcf46b-refs/branch-heads/4324@{#1784}),platform=Windows NT 10.0.17134 x86_64) (WARNING: The server did not provide any stacktrace information) Command duration or timeout: 1.05 seconds Build info: version: ‘2.53.1’, revision: ‘a36b8b1cd5757287168e54b817830adce9b0158d’, time: ‘2016-06-30 19:26:09’ System info: host: ‘DESKTOP-5TB3F98’, ip: ‘192.168.0.110’, os.name: ‘Windows 10’, os.arch: ‘amd64’, os.version: ‘10.0’, java.version: ‘11.0.9’ Driver info: org.openqa.selenium.chrome.ChromeDriver Capabilities [{mobileEmulationEnabled=false, timeouts={implicit=0, pageLoad=300000, script=30000}, hasTouchScreen=false, platform=XP, acceptSslCerts=false, goog:chromeOptions={debuggerAddress=localhost:60700}, acceptInsecureCerts=false, webStorageEnabled=true, browserName=chrome, takesScreenshot=true, javascriptEnabled=true, setWindowRect=true, webauthn:extension:largeBlob=true, unexpectedAlertBehaviour=ignore, applicationCacheEnabled=false, rotatable=false, networkConnectionEnabled=false, chrome={chromedriverVersion=88.0.4324.96 (68dba2d8a0b149a1d3afac56fa74648032bcf46b-refs/branch-heads/4324@{#1784}), userDataDir=C:\Users\mcm\AppData\Local\Temp\scoped_dir5436_463935863}, takesHeapSnapshot=true, pageLoadStrategy=normal, strictFileInteractability=false, databaseEnabled=false, handlesAlerts=true, version=88.0.4324.146, browserConnectionEnabled=false, proxy={}, nativeEvents=true, locationContextEnabled=true, cssSelectorsEnabled=true, webauthn:virtualAuthenticators=true}] Session ID: 08d608b5f33ef2292e5bd7a853e29a88 2021/02/09 10:57:24 - Start Browser.0 - Finished processing (I=0, O=0, R=0, W=0, U=0, E=1) 2021/02/09 10:57:24 - WF_GuiSearchData - ERROR (version 6.0.0 from 2020-12-29) : Errors detected! 2021/02/09 10:57:24 - AutomationEdge Process Studio - The workflow has finished!! 2021/02/09 10:57:24 - WF_GuiSearchData - ERROR (version 6.0.0 from 2020-12-29) : Errors detected! 2021/02/09 10:57:24 - WF_GuiSearchData - ERROR (version 6.0.0 from 2020-12-29) : Errors detected! 2021/02/09 10:57:24 - WF_GuiSearchData - Workflow detected one or more steps with errors. 2021/02/09 10:57:24 - WF_GuiSearchData - Workflow is killing the other steps!
Hi Siddiqui,
Thank you for writing us.
Please refer to our below knowledge article which we have published on support portal.
Feel free to write to support@automationedge.com if issue still persist .
Regards,
AutomationEdge support
Hi @Sidddiqui
1.Please check if you are entering correct URL, username and password.
2.If all details are correct, please check your license validity.
3. If license is valid then please help us with logs to rectify issue.
You can raise ticket to support@automationedge.com
Regards,
