Have ever tried the Google Vision OCR Plugin in the Process Studio?
On the Google Vision Part, I’m getting error " Invalid API Key".
Do you now what are the steps that it should be in Generating the API Key?
By the way Im using 12-Month Trial in Google Cloud.
Hi Karloa, I just past through this process and it was a little complicated with all the security features in Google Cloud.
The steps are rather simple, create an account in Google Cloud, create a project, then go to credentials and create a new credential, where an option is API key. This will generate a code, which you then use in the AR.
Hope this helps.
