I am setting up Remedyforce integration with Automation. I have completed AE installation with Apache Tomcat as the Web Server. Please recommend if I can host the Remedyforce integration services on the same Tomcat Server?
We recommend setting up a separate Web Server (e.g. Tomcat) on a separate machine other than AE. for Integration Services. If not, at least the Tomcat for integration services should be different from AE Tomcat, and the port of integration service should be other than AE cluster ports (i.e. 5900 port).
In the case of High Availability (HA) Cluster, installing all integration services on different machines other than AE is recommended.
