Hi Team,
Issue:- I want to run my bot whenever database get updated through trigger.
Could you all please help me in this issue?
Please comment if there is any clarification required. I am reachable at my Mob No.
Thanks,
Shoaib
Mob No. -7987379392
Hi Team,
Thanks,
Shoaib
Mob No. -7987379392
Hi Shoaib,
You have to write a logic in the workflow/process where it will check whether the database gets updated or not. If the database gets updated, it processes further with required action and if the database not updated, it simply aborts the process.
You can deploy this process/workflow on the AutomationEdge server and schedule a job for the same(every 5,10 minutes) as per your requirement. This bot will run at the scheduled time and perform the action specified in the workflow/process.
