How to auto-refresh Pie Chart in Excel when data is updated by Process Studio?
I am using AutomationEdge Process Studio to write/update data into an Excel file using a template. In the same Excel file, I have created a Pie Chart based on this data.
Currently, whenever Process Studio adds new rows or updates the data, I have to manually refresh or reselect the data range for the Pie Chart in Excel.
I want the Pie Chart to refresh/update automatically whenever Process Studio updates the Excel data.
Please suggest the recommended solution for this use case.
When you create a Pivot Chart, Excel automatically creates an associated Pivot Table in the sheet (or in a new sheet). The chart is always linked to that Pivot Table.
Therefore, even if you are mainly using a Pivot Chart, the actual data refresh happens at the Pivot Table level.
Recommended approach:
  1. Open the Pivot template file.
  2. Locate the automatically created Pivot Table (linked to the Pivot Chart).
  3. Right-click on the Pivot Table.
  4. Select PivotTable Options.
  5. Go to the Data tab.
  6. Enable “Refresh data when opening the file.”
  7. Click OK and save the template.
