I’m facing an issue while generating a Pivot Table/Chart with dynamic data using an Excel template in PS
When I write data dynamically into the template, the Pivot Table only reflects the first row, instead of the full dataset. However, if I use a pre-filled (static) table and just append data in fixed rows, the Pivot works correctly and shows all data.
  • Why does the Pivot Table not refresh properly with dynamically written data?
  • How can I ensure it considers the entire dataset (dynamic rows) instead of just the first row?
handle this would be really helpful!
Please try refreshing the Pivot Table after dynamically writing the data.
Right-click anywhere inside the Pivot Table and select Refresh under the Data/Refresh options.
This should update the Pivot Table with the latest data. If the issue persists, please verify that the Pivot Table’s source data range includes all the dynamically added rows.
Refreshing alone won’t help if the PivotTable’s source range is still fixed to the template’s original rows. A PivotTable caches its source range, so rows written below that range are ignored. Check the PivotTable source; if it is a fixed range, either convert the source data into an Excel Table/ListObject and base the PivotTable on that table, or update the PivotTable’s SourceData to the full used range after writing the data, then refresh.
