Hi Gaurav,
Thanks for your input. However, I have tried with the same logic before in Modified Java Script Step, but it did not work. The required Email is not getting retrieved. Please note the excel that I used contains one DOB as today’s date (Oct 12).
Thank you for your input.
However, with your given solution it didn’t work either. Later on I found out the actual issue in the code itself. I altered the code logic and it worked finally.
