How To generate Refresh Token For Microsoft OneDrive
Hello Madhuri,
Please refer to AutomationEdge Beta Plugin reference to guide.
https://t3.automationedge.com/resources/AutomationEdge_Beta_Plugin_Reference_Guide.pdf
I have used that… But I am not able to understand how to get Response type, Scope , and redirect url.
Waiting for response.
Hello Madhuri,
1] Response Type - Code
2] Scope - Is valid permission, you can give it according to your need. The same is mentioned in the AutomationEdge Beta Plugin Reference Guide.
3] Redirect URI - Any valid https URI is supported. ex - https://example.com (replace it with the desired URI, while creating App in Azure AD).
For example -
This query you can use as an example -
" https://login.microsoftonline.com/common/oauth2/v2.0/authorize?client_id={client_id}&scope=files.read Files.Read.All offline_access User.Read &response_type=code"
