How to replace numbers into String
Give me the solutions If Big number Replace into String
Are you implying that you need to change the data type?
If Yes then you can utilize the “Rename Fields” plugin. By using this plugin, you can easily convert the data type from number to string. Alternatively, there are other solutions available as well.
Thanks for your reply
