Number value converted as float while read as string hence facing issue in stream lookpup plugin
Dear Team,
Number value converted as float while read as string hence facing issue in stream lookpup plugin while matching lookup fields.
Please let me know the solution of above mentioned issue… as early as possible.
Regards,
Rahul h
Hi @Rahul,
Could you get a solution to your problem?
Yes solved by using the javascript.
