How Validate Files extensions
You can validate file extensions by first using the Get File Name plugin to extract the file name from the path. Then, use the Split or Formula plugin to separate the extension using . as the delimiter. Once the extension is extracted, apply the Filter Rows plugin to check whether it matches the required formats (e.g., xlsx, xls, csv).
