In parent workflow I have 4 child wf and I get error in any child wf so how can we know that in which wf i get error on t3 portal
Hi Omkar. if you implemented error processing, you should log errors and download the logs from the agent where the WF was executed. Then you can check which child generated the error and which error.
Hope this helps.
Thanks for your suggestion i will try this definately
