I deployed web-GUI workflow on t3 portal and try to execute but getting request status is failure. If i run same workflow on process studio it’s working fine.but if i run this on t3 portal then get I get Could not prepare output file file:///I:/AutomationEdge/ae-agent/storage/DIGWIJAY_MURUKATE/24311539/OUTPUT/MemberList error
Hi Digvijay,
As per your query, could you please let us know the AE - PS version?
If you are using the latest Process Studio 6.1.0 then please follow the steps below:
- if you have created a project and you have workflow in that, kindly right click on project edit project and select the main workflow
- then you can right click on the project and click on publish, you will have to go through the multiple steps to publish the WF on the server
- After you do so, kindly open workflow on the Server and enter the execution time and parameters and save it.
Kindly try the above and let me know if you have any further queries.
