(Process Studio Version: 7.0.0)
Hello Habibur,
From AutomationEdge 6.0 onwards, we need to publish the workflow from the process-studio. Select the project & do right click & click on publish option.
On UAT/DEV AE Instance:
- Use Publish option from process-studio to upload the workflow on the AE server.
On PROD AE Instance:
First Publish the workflow on UAT/DEV server using process-studio
Export the workflow.zip from UAT/DEV server
Upload the same workflow zip file on the PROD server using Import option.
Hi Habibur,
Delete the project from process-studio and import it again. Then try to Edit Project and fill in the details.
Thanks a lot Rakesh. Now able to publish.
