Intelligent Document Processing by Blox.ai leverages AI with programmable automation. And what can you do with it?
- Convert data from semi-structured and unstructured documents into usable, structured formats.
- Enable faster and more accurate processing of documents across use cases (Listed at the end!) with organized data that is optimized for downstream processes.
How It Works
- The Blox.ai Intelligent Document Processing solution uses Natural Language Processing (NLP), Computer Vision (CV), Optical Character Recognition (OCR) and machine learning tools to identify, label, and extract relevant data from any input document.
- The extracted information is mapped into a structured format while the AI configures a model which can be applied to all similar document types.
- The structured data is then matched, qualified, and reconciled against specified guidelines, thresholds, or other documents based on business needs.
- The output is pushed to downstream systems automatically.
