Problem Statement:
Opening Process Studio gives error "Invalid License".
Troubleshooting:
Please verify that the server you are connecting to has a valid UAT/Dev/Trail* license. Process Studio needs either a UAT/Dev/Trail license to work. It will not work with a subscription License (Production).
Please ensure license MAC address and system mac address are same.
Customer ID, license ID should match with license file data and Operation type is set to “Create”.
Solution:
Install AutomationEdge on another server
Ensure that there is no AE license on this server (Delete license entry from DB as well)
Apply for UAT/Dev/Trail* license
- To check UAT/Dev/Trail license eligibility write to support@automationedge.com
