Hello @Arun9047
There can two possibilities -
1] AutomationEdge license has been expired or
2]The license which you’ve uploaded on AutomationEdge is invalid.
Note - Make sure the license is valid and not expired.
Once this is done, Process Studio will run successfully, by taking the valid license.
I have uploaded the license and the started the instance but while login to the process studio its showing license expired. what i have to do for process studio after the uploading the license. i need asistence.
Hi Arun,
What type of license you are using? Trail/UAT/DEV/Subscription?
Can you log in to your AE server and share the screenshot of the Home page.
i am using subscription and dev
Hi Arun,
I hope you are connecting your process-studio to the Dev server and not to the Prod(Subscription) server. You can’t use process-studio with a Subscription license.
I can see 2 PS in your Dev license and both of them are consumed. If you have registered 2 process-studio with the Dev server earlier and trying to start the 3rd process-studio then it’ll throw an error. You have to de-register 1 of your process-studio first to start a new PS.
Thank you,
now my new process studio register with new user.
But i can’t de-register or login to older one its showing
"“process studio already register with the user” but used same user name and paswd
Hi Arun,
You can de-register it from the AutomationEdge server as well.
Login to your AE account with Tenant-admin credentials
Go to the Process-Studio section
Click on Assign License and de-assign the license for a specific user
If you are using a T3 cloud instance, then the de-registration will happen after 24 hours.
Explore the forum
Error! : Can not instantiate browser due to compatibility issue
Kindly help to resolve this error.. and i need to know another one thing.. while we purchase license how many agents will allocated for subscription and dev
