Knowledge Article :: Unable to load process info from XML node
Problem Statement:
Error Pop-up window in Process-studio.
Error Message:
“Unable to load process info from XML node. Maximum wait time of 10 seconds exceed while acquiring lock”.
Solution:
-        Go to “C:\users\admin” location.
-	Delete “.pentaho” folder from this location.
-	Restart the Process-studio and try again.
Note - In case unable to resolve issue with above solution, write to support@automationedge.com
