Problem Statement:
If you face error while starting Process Studio like
Solution:
Check environment variables & values for it.
Make sure you have set JAVA_HOME, JRE_HOME & Path variables with respective values for each.
like-
JAVA_HOME= C:\Program Files\Java\jdk1.8.0_152
JRE_HOME= C:\Program Files\Java\jre1.8.0_152
PATH= %JRE_HOME%/bin;%JAVA_HOME%/bin;
