I just want to know that difference between regular and singleton also the priority
A regular workflow executes in a non-sequential (parallel) manner, meaning multiple instances of the workflow can run simultaneously. This is useful for high-volume tasks such as data processing or data massaging, where independent executions can happen at the same time.
A singleton workflow is a special configuration applied to a regular workflow. When a workflow is marked as Singleton, the AutomationEdge server ensures that only one instance of that workflow runs on an Agent at any given time, regardless of its non-sequential design. Any additional trigger requests will wait until the current execution is completed.
Priority in Workflows
Priority defines the execution order of workflow requests when multiple jobs are queued.
High → Executed first
Default → Executed after High
Low → Executed last
Priority can be set during workflow creation or update in the workflow editor.
