In the Modified Java Script Value, fields tab there is an option called "Replace value ‘Fieldname’ or ‘Rename to’. What is the use of this tab?
Hi Akshay,
In MJS Field tab, ifyou specify values under field name & rename to then automatically the name of the field under field name will be renamed to the value specified under rename column(So value for Replace Value Fieldname or Rename to will be considerd as Y i.e. Rename to is true).
And if you created any new varible in MJS, but the same field is already present in existing stream & you want to override that with newly created one then Specify Y under Replace Value Fieldname or Rename to( i.e. Replace value is true)
