Modified Java Script Value.0 - ReferenceError: "field" is not defined. (script#3)
Hi
I’m reading an xls file using Microsoft Excel Input step and Modified Java Script Value step for transforming strings and dates
I see the following error when I try to get the declared variables (Get variable button):
Modified Java Script Value.0 - ReferenceError: “field” is not defined. (script#3)
js code:
var test = field_Date;
var test2 = field_str;
var test = field_int;
Fields with numerical values are obtained without problems.
Fields are being displayed under Input Fields.
Thanks
The problem was in the names of some that had the same prefix. I changed the name of the columns and it worked.
Name before:
abcName
abcDate
abcCode
Changed to:
Name
Date
Code
