I am trying to convert a PDF file to a Text file using the ‘PDF to Text’ operation but it is neither processing the PDF nor converting it into the text file. Can you please help? The process is running successfully, but without any conversion.
Hi Sourav,
The issue is occurring because you might be using image type pdf instead of text type pdf.
One solution you can try is converting pdf to image and then image to text using OCR plugin.
Are you searching for a conversion solution to Import PDF file to Text effortlessly? Use CubexSoft PDF to Text Tool Converter for this purpose which gives a perfect and exact solution of how to convert a PDF email to Text. There is no conversion issue you can simply export PDF files into Text file format. The software is a desktop-based application which supports all version of Windows i.e. 11, 10, 8, 7, 8.1, vista etc. If you want to grab more knowledge about the software working, download PDF to TXT Tool demo version. The software demo version allow convert of first 5 PDF emails to Text for free of cost.
