Did you know about PDF to Text Step📃?? Easy way to extract pdf data
Handling many PDFs??
Want to gather all data in one place???
Look Here, We have an easy solution :
Go to Process Studio, and create a workflow
We have PDF To Text Step that easily convert whole PDF data in 2 easy steps.
Get all the file names from the “Get file names” Step (Multiple files case).
Connect Step “PDF To Text” and choose a ‘filename’ from the previous step. If the PDF is protected with the password, provide the Password in PDF Password field.
Store the Output from this step in a Text file (or .docx file using suitable Scripting Step) and manipulate the data as you want.
Note : This is a simple use case, you can implement a workflow as per your scenario/requirement.
We have attached the sample workflow for reference.
WF_PDFtoText.psw (15.7 KB)
