What is Process Studio?
Hi Poonam,
PS is easy to use. Every process is created with a graphical tool where you specify what to do without writing code to indicate how to do it; because of this, you could say that PS is metadata oriented.
PS can be used as a standalone application, or it can be used as part of the larger Suite. As an ETL tool, PS supports a vast array of input and output formats, including text files, data sheets, and commercial and free database engines. Moreover, the workflow and process capabilities of PS allow you to manipulate data with very few limitations.
Thanks,
Snehal.
