I want to read emails from the inbox and process them. After reading emails should be shifted to the processed folder of my mailbox. Kindly suggest the solution.
Hi Sagar,
You can use ‘Get emails from POP’ entry of process to read the mails.
Go to configuration- Settings tab- IMAP settings. Select ‘Move message to folder’ option for ‘After retrieved’ field. Select target folder (Processed folder in your case) in ‘Move to folder’ field.
With this settings, once mail is read, it will be shifted to the target folder.
