Regarding the AE Server
I want an confirmation regarding my flow of the WF + Agent + Server Collaboration. Please provide me the enhanced flow if there exists any apart from mine.
Set it into Main File
Customise the Workflow
Make sure to turn on the Agent
Assign the Agent to the Workflow
Submit the request from the Catalogue tab
Check the status from Requests tab.
If anyone has more optimised way to do this process and flow. Please specify.
Aditya Honkalas
Hi Aditya,
Below is the end-to-end process covering the complete deployment cycle, from workflow development to final execution and monitoring:
1.Publish the Workflow on AutomationEdge Server
  • Open the workflow in Process Studio.
  • Set the workflow as the Main File.
  • Click Publish.
  • Choose:
    • Create – for first-time publishing
    • Update – to modify an existing workflow
  • Complete the publishing process. Once successful, the workflow will be available on the AutomationEdge Server.
2.Configure the Workflow on Server
3.Assign the Workflow to an Agent
4.Verify Agent Status
5.Submit the Workflow Request
  • Go to the Catalogue tab.
  • Select the workflow and submit the request.
    6.Monitor Execution Status
    • Navigate to the Requests tab.
    • Check the status of the submitted request (New, Execution Started, Completed, or Failed).
    • Review logs if required for troubleshooting.
