Need to rename a folder contains the file. Kindly suggest the same…
Hello @sManikandansampath !
Please follow the below steps to rename the folder.
Step1: We intend to rename sample1 directory to sample2.
sample1 directory contains one text file.
Step2: Prepare workflow as below:
Step3: Open “Generate Rows” step and substitute value as below:
Step4: Open “Execute a process” step and substitute value as below:
This step will execute the batch command to rename the directory.
Output: After executing the workflow we will get below output:
