Rename Field set use
Apart from renaming fields, what is Use of Rename Field Step?
Rename Field Step also useful for Removing unwanted fields and changing Type of field.
Hi Pradeep,
The Rename fields step is useful for selecting, removing fields from current stream Also it is used for changing data types and configuring the length and precision of the fields in the stream.
