Passing excel into workflow, performing web GUI based on shared details in excel and save into output excel, then return the output excel from workflow into chatbot. (Excel value reading and passing on 2nd workflow). I can able to save into excel, but couldn’t able to return. Kindly suggest the same…
Hi Manikandan,
You can make use of the blocking steps so that you can read the data after writing is completed.
