Runtime parameters and configuration parameters
difference between runtime parameters and configuration parameters
Hello meghakalyanshetty,
We provide values to runtime parameters during the execution of workflow from the Catalogue tab in AutomationEdge, whereas Configuration parameters are provided one time during uploading or updation of workflow. The values of configuration parameters remain default throughout the execution of the workflow.
As we can see in the screenshots runtime parameter value is provided during execution of the workflow and configuration parameter can be set with default values on editing the workflow or it can be set to default when you upload the workflow.
Thanks you @aditya.devi and @KalyaniW
