How to use Table compare?? If I want to compare values of two column in different tables.
want to compare values of DR and CRAMT
We can achieve the use case using a combination of the following steps: Microsoft Excel Input, Stream Lookup, and Filter Rows.
Attached is the screenshot and workflow for the same.
Screenshot:
Sample Excel Input:
TableCompare.xlsx (8.0 KB)
Workflow:
WF_TableCompare.psw (23.5 KB)
To know more about How to use the Table Compare step, you can check the AutomationEdge Advanced Plugin Reference Guide for more details.
Link: https://rpa.automationedge.com/hubfs/AE%20Release/AutomationEdge_R3.2_Plugin_Reference_Guide3.pdf
