Dear Team,
Excel1 - NEFT_Name
Excel2 - Cust_Name
1.Search excel2 with Like option in column NEFT_Name. if matched, should return. ex., compare the value “Sun Market” and return as “Sun Marketing Ltd”.
Stream Lookup- will return with only match value, my case need to use like option.
2.Failed row values alone (ie., not matching values) should be display in red color.
Dear team,
Can i get any suggestion for this query
@sManikandansampath
1] You can use Filter rows for comparing the tables.
2] You can use any Error handling step.
Hello @sManikandansampath !
Please refer the below screenshot. I hope you are looking for something like this.
We couldn’t able to use the filter row for 2 different excel inputs
Excel contain more than 2000 rows. It’s retrieved only 1000 rows. Pls advice the same…
I have added one new row in each of the input excel file as below:
Input Excel File1:
Input Excel File2:
Based on above input files I have created workflow like below:
You can refer above screenshot. I hope you are looking for same output. And based on flagfield field you can do your further manipulation.
I am attaching my workflow for your reference.
WF_Empty.psw (29.0 KB)
