How to use set field to constant value A in Calculation step
Hi Sridurga,
Set Field to constant Value A is an inbuilt Function provided in Calculator Step.
It is used to assign a constant value to variable.
In Calculator step we cannot directly use any data value, we need to have a value in form of variable. So we can use this Set Field to constant value A and convert data to Variable.
To use this Functionality:
a. In the new Field : define a variable
b.In calculation : select Set Filed to constant Value A function
c. In New Filed A : set the value which you want to assign
d.In value: Set the data Type
Refer the below Image for better Understanding
Thank you Ankita
