WEB_GUI:criteria
if we fetch data from any element and we use Full X-path for that then which criteria we need to use in web get value?
You need to select “X-Path” in the criteria field in “Web Get Value” configuration setting, if you are trying to fetch the element data using XPath value.
Thanks,
Sagar Singh
