When trying to extract an element from a web system, the following message appears:
Unable to find the element with X-Path
And when entering the page and inspecting it finds the element with ease.
I tried to use other forms (ID, name, xpath -full etc)
Does anyone know how I can solve this problem?
Thanks
In this scenario, you need to check whether scrolling is required or the first thing is, you’re searching on the same page or not.
Sometimes the field is inside the frame, so you need to switch the frame or any other possible attributes.
Please check all these possibilities and if you’re unable to find any solution then please elaborate about the site and field which you are mapping.
