What is the difference between WebTable and WebLoop Table plugin?
Hi Shubham,
Below is the difference in Web Table and Web Loop Table :
Web Loop Table - The step is used to traverse through an HTML table in Web GUI automation.
Either the entire table or specific columns can be the output. The Web Loop Table step is designed to be used within a loop.
On drag n drop of this new step, Continue step is also added on the canvas and the validations are the same as the Start Loop-Continue Loop steps.
Each row of the table is processed for a single iteration
(The rows to be processed are specified in the Loop Tab as All or specific rows or based on a condition).
Processing of all the rows specified for a single iteration completes a loop.
The input row and additional fields are passed in the false path after all the rows (as specified in the Loop Tab) are processed.
Web Table - The Web Table step is used to traverse through HTML tables in Web GUI automation. Either the entire table or specific columns can be the output.
Thanks & Regards,
Archana Muley
