What are Metering Units and why do they matter , what`s their use ?
Metering Units represent the license usage or “commercial cost” consumed by the steps and entries in your AutomationEdge workflows and processes.
Think of them like a prepaid balance or credit meter: depending on your license model, certain steps consume specific unit values when configured and executed.
Why do they matter and what is their use?
Licensing budget: Your AutomationEdge tenant or organization operates under an allocated pool of metering/step units. Active automations draw against this capacity.
Design efficiency: Knowing the unit weight helps you identify expensive patterns. If two different plugins achieve the same result, tracking units ensures you aren’t needlessly exhausting your license capacity.
Publishing checks: If your project exceeds the allowed quota, publishing or deployment might be blocked depending on your tenant’s licensing rules.
How to check them in Process Studio
You can inspect unit consumption directly before publishing:
At the Project Level: Right-click the project in Project Explorer → select Metering Units to view the total units across the main file and all child workflows/processes.
At the File Level: Click the details area on the bottom Status bar → select Metering Units to see the footprint of the active open canvas.
