What is use of Add resource file(s) to ZIP archive?
When we deploy workflow/Process on server then it will ask for Add resource file(s) to ZIP archive checkbox, if we select then what is the use of that?
Hi Rajeshwarripawar,
If you click on Add resource file(s) to ZIP archive checkbox, and click Yes. The Add resource files to ZIP archive dialog appears where you can select/add the resource files like .xls, .pdf, .xlsx etc. which you have used in workflow development as input, output etc. to the project .zip.
Regards,
Mahesh
Okay.
I have got my answer. That files are available with project when we export it.
Thanks for help.
This e-mail and any attachments hereto are intended only for the use of the addressee(s) named herein and may be confidential, non-public, proprietary, protected by the attorney/client or other privilege. Unauthorized reading, distribution, copying, saving or other use of this communication is prohibited and may be unlawful. Receipt by anyone other than the named addressee(s) shall not be deemed a waiver of any privilege or protection. If you are not a named addressee or if you believe that you have received this e-mail in error , please notify the sender immediately and delete all copies from your computer system without reading, distributing, copying, saving or otherwise using it in any manner. We do not warrant or represent in any way that this communication is free of malicious software or potentially damaging defects. All liability for any actual or alleged loss, damage, or injury arising out of or resulting in any way from the receipt, opening or use of this e-mail is expressly disclaimed.
