Why Isblank is not work with excel input file which contain empty field
Why Isblank() is not work with excel input file which contain empty field . but it works with csv file .
The difference in how ISBLANK() behaves between Microsoft Excel Input and CSV File Input in Process Studio comes down to how the underlying file engines handle empty fields
Why ISBLANK() Behaves Differently
  • CSV Input: Empty fields are often read as NULL, so ISBLANK() returns TRUE.
  • Excel Input: Empty cells may be read as an empty string ("") or contain spaces, so ISBLANK() returns FALSE.
Recommended Solution
Use:
LEN(TRIM([Field])) = 0
This handles NULL, empty strings, and spaces.
Alternatively, use Null if… before the Formula step to convert empty strings to NULL.
In Microsoft Excel Input, set Trim Type = Both to remove leading/trailing spaces.
