Windows: Restart Services (Plugin Step)
Hi! All
I want to create a workflow to perform Windows machine and services start/stop operations. Please can you give me an idea how to design my workflow.
AutomationEdge’s Windows plugin has several ready actions. Following are a few ready actions related to Windows machine and services start/stop.
  • Windows: Restart Machine
  • Windows: Get Service Status
  • Windows: Start Service
  • Windows: Stop Service
  • Windows: Restart Service
I have designed a workflow with input parameters for Action Type and Service Name if applicable. I have used a String Operations plugin step to trim the Action type string value and convert it to lower case.
  • There is an initial filter to check if the action type is Restart Machine. If so, it follows the path to restart the machine. Else it checks the service status.
  • I then applied a filter to check if the Action Type is to start a Service and perform the action with the ready action for it.
  • I then applied a filter to check if the Action Type is to stop a Service and perform the action with the ready action for it.
  • I then applied a filter to check if the Action Type is to restart a Service and perform the action with the ready action for it.
In this way you can effectively use the prebuilt actions to handle several action types in one workflow.
Great contribution.
Thanks
