About Workflow
is it possible that sharing parameters between both child of a same parent workflow
Yes, data can be shared between sibling child workflows in AutomationEdge Process Studio using these methods:
1. Parent Workflow Stream (Recommended for datasets and multiple parameters)
  • In Child 1, use Copy rows to result to return output data.
  • In the parent workflow, pass the result rows to Child 2 through the Workflow Executor connection configured to return result rows.
  • Map the incoming fields to Child 2’s parameters.
2. Global PS Variables
  • In Child 1, use Set PS Variable with Global scope.
  • In Child 2, retrieve the value using Get PS Variable.
3. System/User-Defined Variables
  • In Child 1, use Set Variable with scope valid in the root or parent workflow.
  • In Child 2, use Get Variable to retrieve the value.
