I am facing problem when i use shared workflow the data which i expect to be copied for the further use but the data is not getting copied to work on, so how can I solve that issue ?
Hi ,
You can perform the required operations on the data within the shared workflow, save the processed data to a file, and then utilize that file in another workflow by invoking the shared workflow to carry out further actions.
