What is the use of “Add value field changing sequence” plugin?
Add value field changing sequence generates a sequence based on Start at and Increment by values. The sequence resets each time a value changes in any of the specified fields in the list. The input data should typically arrive in an ordered fashion although as long as identical values are grouped together in the data stream the step works as desired.
