Process studio (Add Sequence plugin)
What is the use of the Add Sequence plugin?
Hi Minakshi,
The Add sequence step adds a sequence to the stream. A sequence is an ever-changing integer value with a specific start, increment and maximum value. You may use a database to generate the sequence or use a workflow counter in Process Studio to generate the sequence.
