As I tried to start the agent I’m getting the following error message:
WARNING: Using JAVA from path ’“java.exe”’ is not recognized as an internal or external command, operable program or batch file.
the JAVA_HOME Path is Set as below:
Hi Problem Solved.
Just need to add the bin directory to the Path to the user variables as shown below:
