I am getting a memory error when starting Tomcat from Windows services. Please suggest a resolution.
When running tomcat as service, change the memory settings as per the following steps,
- Stop Tomcat Service if it is up.
- Go to → %TOMCAT_HOME%/bin
- Search for tomcat(version number)w.exe (for e.g., tomcat9w.exe) and run it
- Under Java tab change following properties, as shown in the snapshot below:
* Initial Memory Pool: 1024 MB*
* Maximum Memory Pool :2048 MB*
- You may have to increase the allocated memory to higher values depending upon the load on the AE server
(For example if a machine has 8 GB RAM set
* Initial Memory Pool: 2048 MB*
* Maximum Memory Pool :4096 MB* )
5. Start Tomcat Service.
