Append Sheet
when I am writing data into Google spreadsheet using Google sheet: Append row, it gives an error, can anyone suggest what I need to do?
Hello @Shri9764
Please refer to the below answer for your query.
It is caused because the Client Secret is invalid.
Hi @KalyaniW
I have to write the correct Client Secret because the same id I am using for the create spreadsheet
The Connection parameters/credentials remain the same for all the steps.
Hi @KalyaniW
I checked every step but still, the same error, Is there any other way to do the same?
The following error occurs when the Client Secret given is invalid.
Make sure that you give valid Client secret also, check if you’ve all the valid permissions required to perform the actions.
Also, note that - The Connection parameters/credentials remain the same for all the steps i.e. you can give the same credentials which you’ve given in Create Spreadsheet plugin step.
