Hello,
I have a list of files (in csv format). for each file i need to validate if file exists, then if file exist, i need to unzip it and then i need to move the original file to another location.
And as a result of this processing, i need a list of “results” (which files where found, which ones where unzziped sucessfully and wich ones where moved).
As unzip, file location and file move are “process” componentes, i have a parent WF that reads the CSV and then uses “process executor” to do the processing.
But im unable to get the result of the process to the WF.
Is there a best practice for this? i have try to use “set workflow result component” but its not passing the information (it always return “SUCCESS” values)
